21 - 23 of 23 Posts
Hi there! I know this post is fairly old but I just wanted to say that this just happened to me and I am really not trying to spend unnecessary time and funds to have this fixed. After reading the entire conversation, I tried to change the Negative Battery Cable but when installing, I noticed mine looked a bit different. Did you get the exact same one or slightly different? If so, what was the type of cable that you got and where can I get it?
I don’t know if it’s related but i have same problem with my Volt, i leave it on charge over night and i at morning it didn't start up, and showing service power steering on dash, i check the voltage on the battery and there was no voltage, my friend told me to check the charger, the charger was so hot with burning smell and damaged, the specialist told that i should change my electricity supplier. and i had to find another electricity supplier. I found usave to compare and find all the available suppliers in the area. this is what i done a year ago but i faced the same problem this morning.
Started my 2013 cruze today and power steering did not work at all. And a service power steering message was displayed in the dash. I only had the car off for about 5 minuets and it was working properly when I stopped. I shut it back down and restarted and the message was still there. No power steering still..I drove about 1km home tried restarting a couple more times and it still did not start. Got my little guy in the house a couple hours later went back out to check it out it started with no message all worked properly. Checked main power wiring to motor cables are all good. Could this have been a glitch?
And would anyone have schematic or wiring for steering control system? So if happens again I can verify wiring is good.
i have never experienced the sticking while on highway
Hi Jcote i believe there is a recall out for models 2012 2013 about power steering sticking when driving for long periods ,making your steering stiffer to turn your wheels .Mind has a leak in the pump area.will be looking at on Monday.
21 - 23 of 23 Posts
