Service StabiliTack and audio cut off
1299 4
Hello,
My car recently started to display Service StabiliTrack warnings.
Audio cuts off and the display goes off and on constantly.
I remember reading about this problem a year ago.
Now the problem hits my Cruze.
I remember it has to do with a recall on faulty negative battery cable or terminal.
How do I go about getting the problem fixed on the special coverage?
Has anyone had this fixed under the warranty? What does GM do to fix the issue?
Thanks in advance
Here's the link: http://www.cruzetalk.com/forum/25-g...al-coverage-14311-negative-battery-cable.html
Note this coverage doesn't require the dealership duplicate the problem.
Depending on the dealership, you might have trouble talking to them about this - not wanting to hear about what "people on the internet" are saying, or some bulletin you found.
If you run into problems, just schedule an appointment with the complaints. Leave a copy of the bulletin in an obvious place (perhaps the passenger seat) with the symptoms you're experiencing highlighted. More than likely, the tech will get the hint.
I see. The problem is that I do not have a copy of service bulletin/ recall notice that was mailed to me.
I will prolly need to print it off the link obermd has provided and take it from there.
BTW, how do you file a compliant with GM? I have never done it before.
