1 - 13 of 13 Posts
Hello!
I am posting to this forum today because I am at a loss, we own a 2012 Chevy Cruze LT (1.4L Turbo Ecotec) and in the past few months we've noticed the radio randomly shutting itself off and then back on (the clock doesn't reset), and the "service stabilitrak" warning. We have taken it to a certified GM repair center (Bob Brown - where we bought the car), they've since replaced the radio after repeating the problem themselves, but did not fix the service stabilitak issue as they couldn't duplicate the problem. Our radio is still rebooting itself and the stabilitak warning still occurs - thus why I am posting to this forum. I don't in any way work on vehicles (I'm a technology expert!).
Can anybody help me with what the cause might me? I've read that the negative battery cable could possibly be at fault.
Any answers/replies are very appreciated!
Thank you!
-Austin Cox
No, the only thing they've done was looked at it, said they couldn't repeat it, we took it back and they repeated the problem so they replaced it and cleared the "large evap leak" code because they couldn't repeat it and it's been in our possession ever since. I've heard some people have had good luck with re-seating the fuses under the hood (which I can do), but I'm afraid that would void the warranty if I did that so I'd rather not try it until I'm sure it wouldn't void the warranty.
-Austin
· Moderator
LTZ = push button start. The car would sense you are near and activate a few items that you would be pulling the fuses for if you had the key on your person.
I'm still leaning towards the battery cable if they didn't check the battery for a bad cell.
This car needs the three ground lugs at the left shock tower removed, cleaned, and reassembled with star washers.
Thats the start.....it then needs the negative battery cable tested for resistance.....spec is 200ma but anything over 170ma should be replaced.
If your dealer would simply enter 'Radio shuts off' in the GM diagnostic the information is right there.
There is no need to wait for it to reproduce.....as you know there is no particular 'something' that must occur for it to evidence itself.
Hello!
Thank you!
-Austin Cox
Mine is doing the same thing, Hopefully the battery cable fixes it....
I'll have to talk to the dealer about that, I'll be sure to show them your post too!
Thanks!
· Chevrolet Customer Assistance Representative
Hello!
Thank you!
-Austin Cox
Hey Austin,
Very sorry to hear that you are experiencing these concerns with your Cruze. Please feel free to let me know in a private message if further assistance is needed. Please include your VIN, current mileage, contact info and a preferred dealership to reach out to.
Patsy G
Chevrolet Customer Care
2011 Cruze 107,000 KM same issue as the rest of you, Stabilitrak, clock resets to 24hr time, Limp mode, the only other difference is I put on winter tires and have a tire senor monitor alarm that re -flashes. Does this neg. ground bolts fix work? I have replaced the battery, asked GM tech to have all the connections re-tightend on the battery cables. They replaced the Throttle Position Sensor because of Code P2135. With a $400.00 bill, Still not fixed? This is a common problem that GM fails to recognize as a defect. Back to the dealer in the morning they're at a loss, any help from anybody? I can't even trade this thing off on a new dart because of this issue!!
GM (Read Chevrolet) has identified and provided the steps the dealer is to follow for resolution.
Clearly, your dealer is not looking for the proceedure.......you sure you want to go back to them?
1 - 13 of 13 Posts
