1 - 2 of 2 Posts
Hey guys I had new tires put on the other day. I replaced one rim and one sensor on the passenger side rear. The next day I had a service tire monitor system on the display. I cycled through the info menu and it displayed all tire pressures with the exception of the driver's side rear, which displayed --. Considering this is the one I didn't change I'm a little baffled. I took it to a mechanic today and his tool picked up all the sensors wirelessly which told me they were working. I'm going to try to reset it by letting air out and doing the horn thing but if that doesn't work do you have any suggestions? 2012 ls...1.8liter w/ man. tranny
If your TPMS wasn’t reset at the last rotation then your sensors would not be synced correctly with the DIC display. This would explain why the - - isn’t showing on the correct wheel.
A reset/resync should fix everything. :hope:
1 - 2 of 2 Posts
