The dashes mean the sensor is not giving a reading......not transmitting.
This can be a damaged sensor or its battery is dieing.
Even though the car was fine before I tried relearning pressure without the tool, and then it was fixed, could it be a bad job relearning? I forgot to mention that that tore had a real far fetched reading of 37 which was odd considering I had just filled them allThe dashes mean the sensor is not giving a reading......not transmitting.
Mines a 2011 built may 2011 in lordston if that makes any difference, I thought I had always been able to relearn tire pressure, but I saw the turn indicators queuing the tech to use the tool, so I think mine needed the toolIf a tire is not "reporting in" it will cause the light to light.
What year is your car? Is it an "older" year that can relearn just by changing tire inflation, or does it require the tool?
I think the reason they required the tool in later years its it would have been all too easy for a car undergoing relearn to "learn" someone else's tire in a busy dealership. Naturally, the light would then come on shortly after driving away from the dealer as the wrong wheel is now out of range.
Without knowing details, I wouldn't call it a "bad job" (that would suggest someone did something they shouldn't). But I do suspect that things didn't "go right".could it be a bad job relearning? I forgot to mention that that tore had a real far fetched reading of 37 which was odd considering I had just filled them all
I will after work tomorrow, thanksWithout knowing details, I wouldn't call it a "bad job" (that would suggest someone did something they shouldn't). But I do suspect that things didn't "go right".
Remember, the only way the car knows that a tire is "its" is because it heard an ID during the relearn process. If for any reason, another ID was "heard" during that procedure, that would mess things up. For cars that will accept a pressure change, that could be another car getting its tire worked on. For the others, it could be another car undergoing going relearn at the same time. And since you got a "37", it might have been a car that's running 37 PSI.
So, bottom line, I'd do another relearn and go from there.
