I have a set of four GM rims with TPMS sensors. Asking $300.
Located in Brampton, Ontario. Available for pickup. I will not ship these rims.
These steel rims are OEM for the Chev Orlando. They are 6.5jx16 with an offset of ET41. They have a 5x115 bolt pattern with a center bore of 70.1 mm.
Cleaned and touched up with Tremclad at the end of each season.
They will definitely fit the Chev Orlando and have been mounted and used on a Chev Cruze Diesel. They will also fit a Buick Verano as it is the same platform as the Cruze Diesel.
TPMS sensors are running about $50 a piece lately. Rims are either cheap from CDN Tire, expensive from a dealer or cheap & rusty from a wrecker. Note that aftermarket 'cheap' rims are not 'hubcentric'. A hubcentric rim rests on the wheel hub, hence the 70.1 mm center bore. They are clamped by the wheel bolts. Cheaper rims rest entirely on the wheel bolts. Not the way the engineers designed the wheel mounts!
