1. 2011 Cruze Eco 1.4L, Standard Shift
2. 60000 miles
3. No warning lights, no codes
4. NJ
5. Coming to a stop, in neutral, the engine vibrates more than usually. Started last week, had an appointment at my mechanic yesterday, picked the car back up today, problem isn't fixed. I don't know enough about motors to be sure, but I could see this vibration called rough idle.
Here's a description of the testing I did:
I came to a stop at a stoplight, for me I shift into neutral, let off the clutch, and brake while coming to a stop.
While stopped, the car vibrates. Press the clutch, shift into any gear, vehicle stops shaking. Shift back into neutral, vehicle starts shaking again. Release clutch, still shaking.
Its February in NJ, so the AC is not on, but I did test it with no changes.
Mechanic shop had no clue at first, so they did some research, they came to the conclusion that it was the PCV, so they replaced the valve cover. They couldn't replicate the problem after that, so they figured it was fixed. They also checked my vacuum hoses, and monitored the spark plugs for misfires before the replacement. I picked it up, and while driving home, the problem didn't happen for quite a while, but did eventually start up again.
I spoke to my uncle who is a retired mechanic, and he had never come across this, though suggested a bearing somewhere in the transmission area (sorry forgot exactly the part he said), told me to have the shop check for particles in the transmission fluid when I bring it back in.
I don't know if this makes a difference but just before the shaking issue started, I personally replaced the battery, nothing odd happened during the change.
6. USA
7. LHD
