Shift Knob Manual
6455 Views 9 Replies 6 Participants Last post by  SilveradoWTRT
I was planning to switch out the shift knob on my 2017 Cruze LT standard, but noticed that to put it in reverse there is a button to push. Has anyone figured out how to change the shift knob on because of that button? I wanted to get more of a ball instead of the stock shift knob but I'm not sure if that is possible now because of that button. If anyone has any knowledge on the topic it would be much appreciated.
1 - 10 of 10 Posts
The button your referring too is a reverse interlock. It's a mechanical lever that when you lift it it pulls out of a slot or groove. If you are a bit mechanically inclined you can remove the lever arm or somehow secure it up off the groove. Now as far as a replacement shifter unfortunately many of the new shifters are manufacture unique installation. The old days of screwing it off are gone. You can tear into it to see what your up against or search if any aftermarket company has one. Maybe someone from overseas can chime in. That's the best I can offer for advice. Goid luck in your decision.
· Administrator
Hey guys, so update; I purchased a shifter assembly from a gen 1. I disassembled mine (gen 2). I chopped the plastic rod apart on the gen 1 (the piece that slides over the metal shifter rod to make the reverse lockout capable) and adhered that to the reverse lockout plastic on the gen 2. The only thing left to do is get the shifter on and I’m all done. I’ll send some pictures when it’s all done. This was a really big job for what’s being done. And it’s worth it to me because of how much I disliked the gen 2 shift knob. But almost not worth it.
2018 Cruze Hatchback RS Premier
Looks good
1 - 10 of 10 Posts
