1 - 1 of 1 Posts
Brought down from General forum. Had P0011 issues and hesitation. Should have posted it here to begin with!
P0011FIXED!!
I resolved the P0011 issue with 3 oil and filter changes (total) with Seafoam in the crankcase as a cleaner (350 miles between last 2).
Still have hesitation in the shifting between 20 to 40 MPH. No hesitation when shifted manually.
Took to dealer (I know,I know) for diagnostics check and they said they couldn't duplicate. They did change the Neg batt cable under extended warranty.And they found NO codes.
Next step is to change the trans fluid again (this will be the 3rd time in 5K mi). Any recommendations on some additive to clean up the trans??
After that, will be pulling trans pan and checking the solenoids.
ED
1 - 1 of 1 Posts
