Check for JC Whitney coupon code online sometimes you can get up to 20% off at check out.
JCW06JN $20 off $100 or $40 of $200.Check for JC Whitney coupon code online sometimes you can get up to 20% off at check out.
Ill try to post a photo tomorrow of what they look like on the car.
New. The stock rotors are cheap junk (as evidenced by their price).
Edit: Get your hands on some Centric Premium blanks. Top notch stuff.
The high part pricing has more to do with volume.......a dealer doesn't have high buying power.....most will only inventory two of the highest moving part#Stealer ship that's why, they are sub par quality.
Sent from my SM-T560NU using Tapatalk
Maybe in the past and/or on more expensive GM cars, but this is a Cruze. The rotors and brake pads are both junk, as are the sway bar links.My experience with GM brake pads and rotors (and shocks too) is that there is the part that your vehicle left the factory with. It is very expensive and often not even offered by dealership parts people because of the crazy price. These include FNC treated rotors.
Then there are service parts that are priced to compete with the aftermarket. This would include AC Delco.
So about 15 years ago the true factory rotors for my 9C1 were $259 compared to the GM service rotors at $89.
Which rotors and pads did you use?Maybe in the past and/or on more expensive GM cars, but this is a Cruze. The rotors and brake pads are both junk, as are the sway bar links.
Idk, they might be better on a Diesel one with the upgraded brake package.
I had shaking rotors within 9000 miles, and then once resurfaced by the dealership, had them return in another 10,000 miles. Replaced at 25K, now at 45 and have no complaints whatsoever about my new pads/rotors - no shaking at all even under hard braking.
Centric Premium rotors & Akebono ProACT 1522 Ultra Premium pads.Which rotors and pads did you use?
Need to re-do the drums too - the right rear squeals like crazy if it's been the least bit damp outside.
Thanks. Going to save this info for when I do need new brakes...Centric Premium rotors & Akebono ProACT 1522 Ultra Premium pads.
