I hope the title is suitable (sometimes simply questions turns out to be less than simply
I'm thinking about adding some DRL to my cruze. I was hoping I'd be able to take advantage of the 'Automatic HeadlampSystem', that should turn on the headlights when the light sensor finds the surroundings dark enough.
However, I can't seem to use this function as my headlights are always on (unless I turn the lamp control all the way to the left, and everything turns off).
I am wondering if I'm just too dumb to figure out how to use the control settings (I hope not), or maybe It's a 'factory-setting', since the car doesn't have DRL, so using 'Automatic Headlamp System' isn't an option (in daytime I would then have no lights on at all, which is required by law here).
So, can anyone give me a quick guide on how I can make sure I have tried the right settings for using the 'Automatic HeadlampSystem'?
