Single click, no start
935 15
2013 Cruze. Starter will click once, but car will not start. Installed brand new stater, checked battery and fully charged. Lights work, all dash lights work along with radio. Motor turns manually so not the motor. Negative battery cable replaced. Still only the one click. Anyone have any thoughts on what the problem may be? At a loss at this point.
1 - 16 of 16 Posts
Any engine codes? Check cranking voltage.
I don't have that info. The boyfriend and his buddy tested
That info would help a lot. Battery voltage before starting and voltage when trying to start.
they can say it’s good all day but the voltage may tell me otherwise. Not saying he is wrong but people have different opinions on what is good. Voltage readings will confirm.
Is the motor physically cranking over on the starter or is it just clicking?
You know the starter and battery are good so..
If its not cranking then you have a bad cable connection between the battery and the starter.. either on the power side or on the ground side... I.e lots of current has to flow from the battery to the starter and back to the battery again.
Discussion Starter · #14 ·
Found issue. The fuse box battery terminal!
1 - 16 of 16 Posts
