Warm temps + low octane gas often do this to the 1.4Ts especially with the AC running. Try a tank of 89-93 if you aren't running it already.
Check the coil pack springs and resistors are clean... I had 2 that were done at 36k miles and the coil pack was fragged because of the corrosion.
288078
Huge thread on this... but install some NGk plugs at .028 or a fuzz less make sure your springs are clean and you see clean contact point with the coil pack.
