1 - 3 of 3 Posts
Hello,
Been on these forums for a while now and they've helped be on many different things with my car. But this car has been through so much the last few years (under warranty) but just recently about 2 months ago there was a slight oil leak coming from what looked like the bell housing took it in and it turned out to be the oil pressure sending unit (in the oil pan) and the transmission oil cooler lines. Those were fixed. In 2016 the Turbo and Nox sensor were replaced since the Nox sensor took out the turbo from there to software was updated. Also in 2016 the DEF tank reservoir was replaced. But now recently the car on startup has a slight shake to it (goes away after 5-10 seconds and then has a slight hesitation when hitting the gas (only after I do the initial startup) once I'm driving and stopping it doesn't have that issue. It's not throwing any check engine lights or anything so I'm just not sure what this would be now. I only have 86000 on the car. There's also a couple other issues that I've been having but I'll post them at a later date.
Thanks for all your help!
Try giving the EGR and throttle plate a cleaning. Some have had tons of soot buildup clog the EGR and cause jerky acceleration.
1 - 3 of 3 Posts
About this Discussion
3 Participants
Blasirl
Chevrolet Cruze Forums
Full Forum Listing
