One time, I managed to strip the threads of the lug nut while it was still on the stud. It would spin freely, but wouldn't come out and off the stud, and the wheel was still on...there a .50 knrul so any honda stud will work if you wanna get some stronger ones
This snapped stud snapped at much less effort than the other ones. All the others took a lot more effort before the wrench clicked. I know, effort is subjective at best.You may want to have your torque wrench calibration checked. In aviation circles, calibration checks on torque wrenches is technically required (annually, I think).
I've discovered that my problem rate on studs has dropped significantly ever since I started using an impact wrench. I know not everyone has access to one though.This snapped stud snapped at much less effort than the other ones. All the others took a lot more effort before the wrench clicked. I know, effort is subjective at best.
I'll disagree with you on that one. Always was taught to hand thread the lugs back on as to make sure you don't cross thread them, which is easy to do with an impact wrench. But to each their ownI've discovered that my problem rate on studs has dropped significantly ever since I started using an impact wrench. I know not everyone has access to one though.
Sent from my Bulletproof_Doubleshot using AutoGuide.Com Free App
Who said I don't hand-thread them in first before lightly running the impact wrench to twist them? I've personally replaced two studs at a Jiffy Lube because I happened to have a hammer and two spare studs in the car. I paid to have a tire rotation done and the guy doing it didn't thread the lugnuts by hand first before tightening them with the impact wrench and cross-threaded them. I nearly called him a blooming idiot in front of everyone, but lucky for him, they were on the rear hub and I could replace them easily. I got that tire rotation done for free.I'll disagree with you on that one. Always was taught to hand thread the lugs back on as to make sure you don't cross thread them, which is easy to do with an impact wrench. But to each their own![]()
True, but you didn't say that in your original post. I'm not being picky here just wanted to make sure others don't get the idea to go nascar style and lock 'em down with the impact. But yes, a hand thread and a light impact works great.Who said I don't hand-thread them in first before lightly running the impact wrench to twist them? I've personally replaced two studs at a Jiffy Lube because I happened to have a hammer and two spare studs in the car. I paid to have a tire rotation done and the guy doing it didn't thread the lugnuts by hand first before tightening them with the impact wrench and cross-threaded them. I nearly called him a blooming idiot in front of everyone, but lucky for him, they were on the rear hub and I could replace them easily. I got that tire rotation done for free.
You can start twisting the lugnuts first so you don't cross thread them, and continue to tighten them with the impact wrench to save time.
This one was hand-threaded 1/3 of the way down and run down with a cordless impact. Definitely not cross-threaded.I've discovered that my problem rate on studs has dropped significantly ever since I started using an impact wrench. I know not everyone has access to one though.
