1 - 11 of 11 Posts
I refilled my radiator fluid.. and drove an hour down the highway to the next town to see my girlfriend. I heard something weird...
When I looked I saw my radiator reservoir was boiling! Steam was shooting out the shoot on the right where it comes out but it wasn't smoking. I totally panicked ...freaked out....
Then I looked.... My radiator cap was not on all the way....err...oops... I just want to make sure that this is what normally happens if you don't have a cap on. It basically boiled for about 5 minutes then suddenly stopped pretty quickly.
Thanks
· Super Moderator
You're not an idiot. You're human.
Now, if you didn't learn from this oversight and repeated your mistake you'd technically be stupid.
Stupid = knowing better, but still repeating the same mistake.
Dumb = not knowing any better and not able to learn the correct method.
Idiot = being a jerk, like peeling your mustang out of cars and coffee right into a tree.
Read more auotmotive mishaps here:
http://www.cruzetalk.com/forum/17-off-topic-discussion/206458-stupid-car-tricks.html
Very common for it to boil if not under pressure. I actually once heard that this was part of the reason a 6L Powerstroke blew head gaskets (I only heard it once and I know it's not the primary reason, but it might've been a contributing factor). Apparently the radiator caps on the 6L Powerstroke didn't properly seal. So there wasn't enough pressure to raise the boiling point and a 6L pretty much just pumped through boiling coolant, which is hard on head gaskets. As I said, may not have been the primary reason the head gaskets failed, but could definitely be a contributing factor.
I'm thinking if it was just for five minutes you're fine. Just don't do it again! :)
· Super Moderator
· Administrator
Don't forget - Insane: repeating the same mistake and expecting different results.
Don't feel bad I did the same thing. Drove about 6 miles and coolant boiled up like you stated but mine was the little plastic cap on the reservoir popped it right off. Was in a hurry to top it off when mine was leaking on the water outlet or upper water neck whatever it's called. In the dark and only got cap on part way.
1 - 11 of 11 Posts
