1 - 16 of 16 Posts
Swapped out my worn original wheel for a Sonic RS flat bottom wheel. Nice thick grips, red stitching and RS logo which is perfect for a Cruze RS. The flat bottom allows a bit more room getting in/out. Took about 10-15 minutes, mostly trying to release the airbag. I did discover the Sonic cruise control switches didn't work (on did nothing and cancel turned the cruise on and it wouldn't turn off). I'll have to take it off and use the original switches and harness.
283346
283347
What did one of those run ya? Looks right at home (especially since yours is an RS).
Well that is a good deal, especially considering it is brand new.
Discussion Starter #5
For sure. Figured it was a good time to get one before it's discontinued. The ZL1 wheel is the same except it has paddles. I guess you could order the RS trim piece and put it on that wheel, but having paddles wasn't a big deal to me.
I don't know how well the paddles work with the 6T35 anyway. I don't mind the way it's laid out in the shifter, to be honest.
Now, in a Gen 2, the paddles would be critical, IMO. That stupid little plus minus toggle button is far less enjoyable to use than paddles or the Gen 1 "slapstick".
weird, my SS sedan steering wheel was plug and play, minus the paddles...but that just took a switch and some wires to get it to work.
Discussion Starter #10
When I researched swapping out my wheel for one with paddles, it seemed all but the Sonic switches worked. Those included Camaro, Impala and Malibu.
Not sure why they don't work, but the original switch to turn on cruise is a rocker vs the new one is a momentary/button. Not a big deal to swap the original switch and plate/harness over.
how do you swap switches? My SS wheel has lane control and front radar buttons on the far left...might want to swap my original buttons back on
This looks great! I wanted to do something similar to set off the RS package for my 17 Hatch. Ended up making vinyl decals not quite as nice as the OEM Sonic but the best I could do on my budget.
I have already completely disassembled the steering wheel and have documented it in the link at the bottom, and as far as the Sonic issues, I included the link with their explanation in my post on installing the new wheel.
It is pretty easy, just a bit tedious depending on the wheel.
How-To: Disassemble a steering wheel to rehab it.
Can you use the cruze airbag with the Sonic RS wheel? I want this as my cars PO must of had very acidic hands and my steering has a somewhat gross spot that has been worn down.
Yes.
Sweet, I hopefully have found an ultra cheap source. Hope to know more tomorrow.
1 - 16 of 16 Posts
