1 - 7 of 7 Posts
Wheel spacers
I'm wondering if there are wheel spacers available for the Gen 2 cruze. Has anyone tried putting wheel spacers on their gen 2 cruze? Anyone tried with stock rims?
Will the wheel spacers people used on their gen1 cruze work on a gen2 cruze? Eibach pro-spacer wheels says it will not fit on a gen 2 cruze, is that right?
Just attempting to get a flush look with stock rims. Does anyone know what things I might need to change if I put wheel spacers on?
ok so I did a little research and I came up with a couple of things...lemme know if I'm wrong...
the bolt pattern for the gen2 cruze is 5x105mm
the bolt pattern for both gen1 and gen2 cruzes are the same
spacers and rims that fit the gen1 cruze should fit the gen2 cruze
so what I'm wondering now is how do I measure to see how far the spacer will push the wheel out?
my thinking is, since I'm going for a flush look, to measure from the tire which sticks out the most and see how many mm it takes to be flush with the wheel well
Play with this:
Custom rims, wheel tire packages for your ride - RIMSnTIRES.com
1 - 7 of 7 Posts
