Wish I had an answer, but I know if I see good results I will be doing this as well.
Sent from my DROID BIONIC using AutoGuide.com App
Well, since I like to document everything, I'll start with the last 5 tanks of gas I've had, from newest to oldest:Wish I had an answer, but I know if I see good results I will be doing this as well.
Spark Plug Installation InstructionsA spark plug's voltage requirement is directly proportionate to the gap size. The larger the gap, the more voltage is needed to bridge the gap. Most experienced tuners know that opening gaps up to present a larger spark to the air/fuel mixture maximizes burn efficiency. It is for this reason that most racers add high power ignition systems. The added power allows them to open the gap yet still provide a strong spark.
I don't see changing your spark plug gap voiding any warranty or breaking anything. Worst case, you get spark blowout and you have to set it back. Really no big deal......Warranty?
It was probably done with the knowledge that people will adhere to the 100k mile spark plug change interval. I think that by 100k miles, the spark plug gap will be close to or even larger than .034. If you start with a larger gap though, your mileage won't be quite as high as you'll have to replace them sooner or re-gap them..029 does seem very small. i wonder what there reasoning was. i really like this type of thread. always have been the type to mod my cars. modding for mileage is fun too. cant wait for hp tuners so i can try some lean tuning.
They are iridium.are the stock cruze plugs double platinum? if so i would think there is very little wear over the 100k lifespan.
I would fully agree with this statement. There was a definite improvement, which leads me to believe that city driving will yield significantly better fuel economy results. More power out of the same amount of fuel.Too me, it felt like the power curve came in sooner and would hold out most of the range.
Emissions perhaps? I recall hearing something about some trace of fuel getting to the catalytic converter.I gotta wonder about this. If increasing the plug gap increases performance and fuel economy, then why didn't the engineers design it that way? This is one of those things where I wish there was documentation about the engineering of the engine.
So are there any downsides to this with the cruze? I have to admit, I'm really loving the results. There's significantly more power at very low rpms (1100-1600), which is where I do over 90% of my driving. I was accelerating up a hill without problems earlier in 6th gear at 40mph. Engine even feels smoother at those very low rpms as it usually vibrates a bit. DIC is reading 40.6mpg with an 18mph average speed, all city driving. I filled up this morning and took my. Wife shopping for 4 hours. I have very high hopes for this next tank of gas.It has to do with burn time and spark intensity. Different gaps create a variable resistance that can be tinkered with to create different ignition conditions. A longer gap = higher resistance which means voltage goes up to jump the gap
