41 - 60 of 254 Posts
We are talking about the cable that runs from the negative post directly to the front cross member where it's bolted on. That's the cable that gets replaced. Are you sure you've got the right cable?
Dealers will replace the battery negative cable, which will now require a bolt to fasten the small regulated voltage cable.
Anyone got pics on what the old and new cable looks like?
I just received the notice in the mail about "the negative battery cable terminal clamp may have an insufficient crimp at the battery" which may cause a host of electrical issues as most of us are already aware. I guess I thought that this was an issue with the early model Cruze. Apparently they did not learn from their mistake? Some of the potential failures include loosing power steering, ABS and Stabilitrac.
I cannot for the life of me figure out how this is not a full blown recall level issue?
It is eerily similar to the ignition switch recall that was so late to be issued.
The funny thing is they do not want you to take it in to get fixed "unless you believe that your vehicle has the condition as described above."
All that being said it is an easy fix that I could do myself and likely will, but it should be taken care of by GM without waiting for failure.
You've answered your own question. It hasn't been ten years yet and no one has died from the problem. I'm sure corporate just views this as a QC issue with the supplier. Also, the complaints at NHTSA haven't hit a critical level, so government will take no action either.
IIRC, the notice came out in December. By that time some 2015s were already out the door.
Is it a safety issue? I think a big issue with the ignition switch is that it caused the air bags to be disabled.
I do not know how long GM has known of this issue or how wide spread the issue really is? Apparently bad enough for them to send out notice of the issue, but not enough to pay for the recall, yet...
I would argue it is a potential safety issue. If electrical systems that control these safety systems, possibly including air bags and power steering lose power and shut down unexpectedly while driving it is a safety concern.
This may be a rare problem, but it seems a number of members here have had some kind of electrical issues related to this bad ground.
I to am curious what the updated cable looks like compared to the original?
I've seen the replacement.....looks the same as what is being replaced to me.
Even the bolt mentioned already exists on the original.
I am forced to WAG that the crimp section, cable to terminal, has been enhanced in some way.
In asking my dealer, after replacement so far, no customers have returned with a repeat failure of any kind.
Hi guys,
Here in Canada I have received the recall letter from GM. Since I had instruments power shutdown 3 times in 2014, I recently bought a new negative cable from stealership at 50$ and changed it myself. I hope they will give me my money back now. I just kept the invoice and old cable just in case.
At the time I bought it, the guy from parts dept told me he has never seen this issue. Thanks to this forum I fixed it before having more problems. (sorry for my English)
the negative battery cable terminal clamp may have an insufficient crimp at the battery negative terminal
Was wondering what this negative cable issue was all about and never received this bulletin. First surprise with my Cruze was GM finally got away from the side terminal batteries. Like everyone else now?
Maybe the engineers never knew the negative battery terminal is about 40 mils thinner than the positive terminal like it has been since the beginning of time.
First thing I noticed about the negative battery cable terminal is that there was no gap where the battery terminal bolt goes through. Doesn't need much of a gap, 1/32" will do, so removed the bolt, used my Dremmel with a thin metal cutting blade where that gap should be so now a small gap in there. Now the clamp can be tightened. This is a terminal for the positive side of the battery not for the negative side!
Bolt was also crap, so replaced it with a grade 8 1/4" X 20, one long, fit nicely in the flat so doesn't turn when tightening the nut. Nut was okay, but tapped it to that 1/4"-20 thread. Didn't redrill it, got a nice deep thread in the nut. Ha, wanted it to look stock.
That stud in the negative battery cable makes it special, didn't measure the thickness of this wire but feel like either a 16 or an 18 AWG wire that just goes under the fuse box. Now much of a current handling wire, could have made it a couple of inches longer to that radiator frame stud to save that stud.
Hmmm, since I cured this very obvious to me problem myself, maybe GM should send me a couple of bucks for my efforts. Paper work alone would cost them a small fortune.
Discussion Starter #53
I went to the dealer yesterday and it seems that I'll receive a payback for my neg cable from GM Canada. The guy asked me why I didn't make it fixed on warranty. I honestly responded that they would not be able to reproduce the problem, and that I found the solution on Internet. He was not smiling at this.
Dealership service people are, in many cases, completely unable to relate to people with mechanical ability. They don't understand why anyone wouldn't want to deal with the service department (?!?).
I avoid dealerships as much as possible and unless a repair costs more than $100 or so I will gladly do it myself instead of getting them to do it, even if it is covered under warranty. The hassle of dropping my car off all day with no appointment, dealing with their shuttle service, combined with the risk of them either not finding the problem or not fixing it properly, multiplied by the risk that they will damage the car or cause other problems... I'd rather not have that stress in my life.
It's much easier to just buy the part I need and fix it on my own time, and on my schedule. Done once, done right.
Not all dealerships are the same... some are really good and have a great staff and excellent technicians. These dealers are hard to find. Mine isn't one of them.
I agree with you 100%. Applies also to winter tire swap in my case. I have two cars, and it takes me only 1 hour to do 8 wheels, on a relax saturday...
Also agree 100%. The dealership service department in this area really sucks. I wish GM would do something to fix this. One of my friends really likes the Cruze, but refuses to buy one because of the bad service at the dealership.
Could this cable also cause problems with keeping the battery charged? I just had to replace the battery in my 2013 Cruze LT because it was sulfated (was just 2000 miles over the 3yr/36K warranty, so dealership said I would have to pay for it....which I did, at Autozone! Got a DuraLast Gold with a 5 yr warranty).
It seems logical that if it develops a bad connection and causes all these DIC messages and problems, that is could also cause a problem with keeping it charged.
