1 - 8 of 8 Posts
Hey,
So I complained a month or so ago about my hub caps squeaking a lot, and I had one of them replaced by the dealer.
well a couple weeks later the squeaking came back and it was even louder!
So I took little bit of silicon brakepad lube and put it around the inside of the hub cap. (Around the outer edge and around the 5 area's behind the nuts.)
no more squeak! :eek:ccasion14:
and the brake lube is water resistant to boot!
Mine have squeaked and I couldn't figure out a fix so I moved the bad one to a different wheel. Something changed and the squeak went away. I'll try some silicone grease if it comes back. I have a theory that the squeak has something to do with how tight you get the plastic nuts but I don't know if that's right.
Most cars hubcaps give a light squeak heard at slow speed and its due to the contact points of the hubcap. normally wiping off the brake dust and shifting from 1 wheel to another fixes your little squeak. otherwise some light grease on the contacts will eliminate the issue.
Trust me this isnt a light squeak, it's so loud that it's embarrassing and very annoying. I think it's why the 2012's have a different model of hubcap. The 2011's just dont fit perfectly I'm assuming.
Also you can't really hear it until your going at least 60.
edit`.
I thought it was the nuts being too tight as well so i tested it, I found tight or not they still squeaked a lot. I think the nuts are fine, my last car had the exact same nut style (Aveo) and they never made any noise.
Well it rained last night... and so much for being water resistant becuase i saw that the lube was dripping down the wheel when i came to my car this morning.
I didn't hear any squeaking so it didn't all wash off... If the squeak comes back im going to try increasing my tire pressure and see what happens.
1 - 8 of 8 Posts
