Just like mentioned above it will shut off when the vehicle is stopped. There is a battery in the trunk on the driver side hidden under the panels and will have a pic of a battery showing where its located. The Gen 2 uses regenerative braking just like the Volt and ELR to charge the battery, then when the light turns green and you start to pull you foot off the brake the computer will sense this and restart the motor and be in gear ready to go by the time your foot hits the gas. GM says the starter is getting the signal to start .08 of a second after it senses your foot leaving the brake.. Also you can control how often the vehicle will shut off, on your climate controls the snowflake is where you select which option you want. When the light is yellow it will be in the comfort mode and will shut off less, when the light is green it is in eco mode and will shut off more often to save you fuel and when you push the snowflake to toggle through it will show you on the MyLink screen also just like when you make a fan speed or temp adjustment.. Anything that you have running in the vehicle when the motor shuts off will continue to run ie: the A/C, radio, anything plugged into power ports like phone chargers etc etc. When i say the air stays on it does but there is a noticeable increase in the temperature of said air and if you are hot natured like I am it will get very aggravating very very quickly.
