Start/Stop temporarily inactive after battery replacement on Gen 2 Cruze
10945 Views 22 Replies 13 Participants Last post by  Barry Allen
FYI, this confused me today when my car stopped shutting off at lights. Apparently it is normal and the car will fix itself after sitting unused for 3 hours.
My car came to me with the wrong battery in the trunk; likely from sitting around since April (I bought it in November) in the showroom. The dealer just threw a non-AGM in the trunk to get it out on the lot. So, after today's service visit, now it has the correct one, and of course the cables were disconnected.
TSB addressing the learn procedure here:
https://www.revbase.com/BBBMotor/TSb/DownloadPdf?id=195551
Condition/Concern:
"Start/Stop is inoperable after any repair where the 12V battery cable is disconnected. No DIC message or DTC code will be set."
Recommendation/Instruction:
The learn procedure needs to be completed on the battery sensor module. It will be necessary to park the vehicle for 3 hours after the vehicle's sleep system cycle and without being driven to allow the learn procedure to be completed on the Battery Sensor Module.
And indeed, after sitting for a few hours, it now works again, and is much smoother/quicker with a battery holding correct voltage. Coincidentally, I read somewhere that the predicted lifetime for regular lead-acid batteries in start/stop service was ~6 months, and sure enough the blue top ACD battery was barely holding 12.0 at times.
1 - 20 of 23 Posts
I hearby sentence you...
Oh goodie j is having problems already with his IT ..............
Interesting, maybe it senses a issue of low battery voltage and disables the start/stop to prevent a no restart condition?.
No issues, just wrong battery.
Start/stop is active again. Just putting this out there if you have something similar happen once it's disconnected.
Probably a good idea to adjust the title to say temporarily.
It sounds like the car needs to build confidence in the battery before trying to assess it's charge state. When in doubt - no stop/start.
My car came to me with the wrong battery in the trunk; likely from sitting around since April (I bought it in November) in the showroom. The dealer just threw a non-AGM in the trunk to get it out on the lot. Coincidentally, I read somewhere that the predicted lifetime for regular lead-acid batteries in start/stop service was ~6 months, and sure enough the blue top ACD battery was barely holding 12.0 at times.
So is the "right" battery one that is not lead-acid?
Should be AGM.
I know people don't read manuals, but in the manual it does a good job of explaining the start/stop. About temperature, battery voltage. Anytime the voltage is too low it will stop. Also if you at a stop and the battery drops or if you have heat or air and the temperature cannot be contained the car will restart.
Yeah, but no mention of the 3 hour sleep cycle thing when battery is replaced in the cars manual. It would probably be a good addition.
So this battery has to be replaced every 6 months? That sucks! How much does it cost?
No...the correct type should last 3-5 years even in a start-stop application. The car didn't come to me with the original battery it left the factory with (dealer screw-up).
This made me check my battery, to make sure mine has the AGM, LOL
Yeah...I would never have looked unless I was poking around in the trunk looking for water leaking from the brake light and seeing if I could avoid taking it in for the recall as long as possible until the free 7k service.
FWIW, this is what was in it...your regular ACD Group 48.
Vehicle Car Subcompact car
Oh, wow. You don't even need to know about batteries, type or what does what, it says right there in plain print that the battery is not meant for this vehicle. The dealer did this? Wasn't aware that dealers provide batteries.
Just an update since I dug this thread up again. My AGM replacement did indeed last 5 years before it started falling to low 12V range this winter. Had it tested and it showed that it needed replacement based on cranking amp availability.
Costco sells an Interstate H7/94R AGM for a pretty decent price.
Gas Machine Electronic device Auto part Electronics accessory
At least yours doesn't just seem to...die...like the 1st gen Diesel's do.
Was your start-stop starting to work less and less? My brother just had the battery replaced in his Regal a few months back and that's what fixed his stop-start issues (it basically never worked since he bought the vehicle a year and a half before)
We noticed absolutely no difference in the behavior of the car like I did back in 2017. It certainly cranks stronger now first thing in the morning, but it wasn't acting like it was anywhere near dead.
Interesting...
Now, I have heard the Regals are quite sensitive to the battery being slightly less than optimal, so maybe that's why. Still, aside from start/stop, his started and ran just fine.
Meanwhile, our two batteries thus far in the CTD have 1) failed while the car was running in the middle of a three-lane 55mph road in heavy fog 2.5 miles into the drive to work one morning (and it took days for the dealer to finally get it to test failed, too) and 2) failed after working just fine when the vehicle was being repaired from the tree incident - my buddy went to go move it and...totally dead. Was fine the day before.
1 - 20 of 23 Posts
