1 - 8 of 8 Posts
I have started to notice that the steering has been a bit more loose than usual and I am not sure if it's maybe from worn tires. But it feels significantly more loose than usual and I have am having to turn the wheel more to turn the car. Any ideas? Is it possible to tighten and adjust he steering ?
It's time for new sway bar links - they don't last all that long.
Check ball joints in the control arms and tie rods for play while you're under there.
Hey j are you telling us that these new fangled Electro Mechanical steering racks have to be maintained with new Ball Joints and such ?
What a rip off . great now we have to be diligent about these newer steering systems !
Thanks! I will check those out. Is there are recommended brand for the sway bar links?
AC Delco apparently has new ones that are metal instead of the plastic design on the car. Probably hold up much better than those plastic things.
I replaced mine with Moogs, but I'm sure there are better options.
1 - 8 of 8 Posts
