1 - 3 of 3 Posts
I need some advice, I am trying to get to speaker outputs to tap in for a sub. But I do not see how to remove my dash. The only video I seen was for a totally differ car and did not match up.
Usually remove the plastic trim surround around the radio and center console and it will be obvious how to slide out from there.
It depends on the radio you have there are 4 different RPOs for radios one of them is actually mounted in the back of the car and has a wire harness running to the screen the others are all mounted in the dash behind the screen only one is part of the screen if you pm me your VIN I can figure out what one you have and get the removal instructions to you
1 - 3 of 3 Posts
