Only in the morning, it seems the stock stereo is always off. I know there is something that shuts it down when I open the door after removing the key. But every morning I have to power on the stereo. Is there a way to change this setting. I have been living with it for the last few years, it is not a big deal, just a nuisance. Don't remember if my 2011 LS was the same or not.
Interesting issue, is the radio in the off state when you turn the car off before starting it in the morning? I believe it should just resume whatever state it was in previous to turning the car off, at least that's how mine acts.
Side note: My mother has the opposite problem on her '15 Chrysler 200, there is no possible way to turn the base radio system off, you can only turn it down. Then when you restart the car, it begins again with the radio on at low volume. It also has 9 gears and shifts way too much. She hates that car.
I leave an old ipod classic 180GB in the center console that has a library of music I listen to. It defaults to either that or XM radio, whichever I left on last and those are really the only two things I listen to.
When I press the start button, whatever was playing when I left the car comes on again. Weather it's a CD or XM radio. If the CD was on when I shut it off, the visual display comes on and finds the track that was playing exactly where it left off when shut down.
When I start the car, 80% of the time, it will resume where it left off when it shut down when I opened the door.
The other 20%, it switches to FM.
On rare occasions, the radio has to reboot twice - but it's never failed to start.
The radio is normally powered 24/7. It's turned on/off by commands on the car's computer bus. However, I have to wonder what happens if the battery saver has to kick in. In that case, the radio may lose power completely.
I had an issue with my old cavalier on cold mornings even with an aftermarket radio it would light up but not allow you to turn it on until you restarted the car the first time. Didn't happen everytime, but seemed when I had a bad battery it happened more often.
The first winter with my cruze it did the exact same thing 6+ times on very cold mornings with the stock battery, I replaced that battery almost 3 years ago with a diehard AGM, has not happened since. The stereo would be lit, but it would not power on on first start up and the buttons did nothing. It would also at times forget the source I had last used, which still happens from time to time with the new battery.
A friend of mine just had his 09 silverado with a bad battery exhibit the same behavior, his stayed in power off state until he replaced the battery though. I'm guessing this must be part of the battery run down protection at work.
I also remember hearing that in some cars, the first sign of a battery going bad was the radio would lose it's station memory. Apparently, the voltage during cranking would drop so low the radio would flip out.
I think the problem is actually how the car is supposed to work. When I get home I will sit in my car for a min and then open the door, and the radio shuts off. Which is how it is the next time I get in. Is it supposed to shut off when you open the door tho.....I know it does after 5-10 min.
Speaking about minor cruze annoyances, does anyone else have the trouble that you leave your ac on and when you go turn it on by remote start or manual the cruze likes to 30% of the time turn the ac off for you and just blow air no ac?
