2013 Cruze 1.8l manual tranny. After OBD scan, this is what I got as issues. See attachment. Is this fixable or should I tow her to GM dealer to work out? Thanks
Background : Had BCM no comm issues. Now resolved when I learned that underhood fuse box X2pin connector was completely loose. Bolt threads were stripped and replaced. All 3 X pins are intact. No fuse/relay/voltage isues with this box what-so-ever -- confirmed. All power/ground/comm wires good to BCM!! Got a check mark on comm to BCM which means it is fine and not needing replacement.
Replaced ignition switch, ( not cylinder), crank & cam sensors, coil pak, spark plugs.
