Was in stop and go traffic on vacation recently when the brakes were squeaking with every push of the pedal. I thought it was the normal "the pads need to be changed" squeak, but after I changed them, the dreaded squeak was still there. It usually happens first thing in the morning during the first few pedal pushes, and of course, it happens when I am in stop and go traffic. Can't tell if its the front or rear or both brakes. Thanks for any suggestions from the wealth of knowledge I know is on these forums.
What type of pads did you use and did you use any high temp lube?
This. More info if you have it. Did you change the front or rear? How long has the squeak been there?
You can get a good idea if it's the front or rear squeaking if you drive beside a brick wall with the windows down, like behind a shopping mall, and apply the brakes while listening.
