After draining the coolant and replacing my thermostat housing, I have run into an issue while prepping to bleed the system. The plastic bleeder valve has quite literally disintegrated while trying to remove it. I attempted to be as gentle as possible, but any force applied to the valve has caused the plastic to crack and strip. The valve hasn't even moved a fraction of a inch. What should I do? It is completely stripped.
