^^id totally be interested if that happens, much rather give my money to this said guy over some over seas company.. what about the front tower bar could he do those aswell
Front bar is a bit more tricky due to the way it's mounted and there not being a simple mounting point. I'll have to look at the engine bay a bit closer.
I have noticed though that the car's chassis twists a LOT in corners, and the rear bar will alleviate a lot of that. For most people, it will fix many of their issues. The front bar stiffens the front of the car, but it may adversely affect ride quality as the chassis is designed to flex a bit when going over bumps and uneven pavement. This removes that flex.
The uppers will be easily done I'm not sure about the rest.
I plan on having most every chassis bar possible on my Car.
Sent from my Droid
The lowers I'm not sure of. It's doable if you have a welder, but of course that's more work.
Yea but what about the other chassis reinforcement bars I would assume those would be a little harder to manufacture.
Sent from my Droid
The front will be your biggest challenge. The rest is just a matter of testing and fitting and welding. You can make your own rear for under $30, hardware and paint included. I'll spray mine with high heat flat black and just bolt it in. It won't look like a fancy UR bar, but for 1/5 the price and more rigidity, I don't really care, especially since you have to duck down to see it.
Based on my experience with the rear strut tower bar on my previous cars, I'd say every Cruze should have one. You will notice an immediate difference in steering response and emergency maneuvering stability.
