Hey, got a weird one for you all. The symptoms are much like the normal pcv or valve cover failure but I replaced the intake manifold and the valve cover a few days ago, and the orange nipple is there and the valve cover doesn't suck at the diagram at idle so it's ok also. But when I open the dip stick it or oil cap it sucks and blows at those points. Switching between the two almost 5 times a sec. But if you cover the hole you realize it's sucking more than blowing. ... The rest of the info is just extra. Not sure if it will help
My 2011 1.4 turbo eco model decided to vomit oil all over the passenger side of the engine. Turned out it was because the pcv was now missing, so the pressure would cause the oil to end up going into the corrugated hose and shooting out all over... Or what didn't continue into the turbo and then into the intake and engine. So I replaced the valve cover and did the V.3 upgrade. However that didn't fix it. So I took it off and replaced the intake manifold just to be safe. but the V.3 does replace the correlated hose. So now the oil just stays inside and goes into the turbo and so on.
The car also sputtering when I drive it. I went on a highway trip after installing and intake manifold and new valve cover but after 20 mins it said "ac off due to high engine temp" but the car never got hot. In fact the needle went from normal temp to 0 or cold. I pulled over and no signs of over heating (bubbling radiator fluid/glowing headers). I turned it off for 12 hrs and came back later. the ac off sign was still active. So idk. Also the oil was a bit over full before I started the trip. Still at the same level now. No change. Also it is sucking at the oil cap and dip stick. I even put a spare valve cover on that was also good just to check for cracks... Getting good at changing this valve cover quick lol
I know the valve cover and the pcv valves are only 2 of three check valves on that system (or I think). Could the turbo check valve (maybe solenoid also don't know) be bad. What does that part even look like.
