2014 Cruze diesel
Fleece Performance full emissions deletion kit with EFILive tuner.
Installed down pipe, did not remove egr and install block plate due to time and finances.
Questions:
Can I still install the "CRZRACE" tune and be safe to drive, replacing the egr at my leisure?
Is there a specific tune file by name for just installing the down pipe and not the egr block off plate? If so which different process do I follow? Process now is "Full1 STCKTUN" then the "CRZRACE" option.
Discription for unplugging the "throttle valve":
"Do make sure you unplug your *throttle valve* (car will not start a second time if not unplugged before start up after tune)"
-When do I unplug it? Before the tune, after the tune? When do I plug it back in? After the tune, after the start? Also, would this be the throttle position sensor / motor? Every throttle valve I know of comes in a transmission.
Questions:
