I've had my 2012 cruze rs for about a week now and at first I noticed the bulb/led that illuminates the blue half of the temperature control knob flickered once In a while at night, now the light has gone completely out so only the red half is illuminated. Is it a simple bulb replacement or if anyone has any insight into how to remove the knob and have a look at the lights behind that would be great.
  • Pry off the Upper Molding (the one that has the center vents)
  • Remove the Control Lever Trim Cover (the part that goes around the shifter and the A/C controls.)
  • Remove the Stowage Tray
  • Remove Accessory Bezel (the one with the hazard light switch
  • Remove the control module from the Accessory Bezel.
Forgot to mention, once you're down to the control module, you're on you're own. No details beyond that.
