Hello X,
I haven't been on here in a couple of months, but I am now ready to start my SQ build. I was going to buy a set of your mdf door baffles, but I found a router and a bunch of bits cheap at a yard sale and I think I'm gonna give it a go on my own. I was wondering if you would be willing to share your demensions for the baffles? I will be running Silver Flute 6.5" 4ohm in all four doors. The rears will be mid-bass only. I bought two MiniDSP kits and will be using one for mids and tweets, and the other for mid-bass and sub. Tweeters will be a pair of Vifa soft domes (the ones you recommended,) and the sub an Alpine SWS-15D2.
Everything will be powered by a pair of NVX 800.4 amps (probably a bit more power than I need.) I've never ran NVX before, but was impressed with their specs, and failed to find a single bad review on them. They are class D and are really tiny, only about 7" x 10.5". I should have no trouble mounting both amps to the back of the sub box.
The sub box (which I already built) is 2 cubic ft, sealed, 3/4" mdf with a double thick front baffle and bracing inside.
I am going to build my own rca cables using double shielded cat5e and cast Amphenol connectors that I got from Parts Express. The primary power cable is 1/0 pure copper welding cable which will split into two 4 awg welding cables in the trunk at the dist block. The welding cable will also be used for amp grounds, and a new chassis ground at the battery.
I got CLD tiles, MLV and CCF from Don and will be installing that soon.
Anyway, I'm taking lots of pictures and will be posting some soon. Again, I am wondering if you will share the baffle demensions, Xtreme? I don't have much experience with routers yet, but I think I can do ok if I start out with the right meaurements.
More to come....
