1 - 4 of 4 Posts
For a limited time, get free shipping on Quick Time electric exhaust cutouts, controllers, and accessories from PFYC!
Free shipping is available in the lower 48 states using promo code QTPME until May 28, 2013.
Unleash The Power! Go from quiet to aggressive with the flip of a switch or remote button with our ultra high quality electric exhaust cutout. You can have the best of both worlds! Quiet for the street and wide open for the strip or show. Go from stealth quiet to wide open power!
You control the volume, you control the power. Open your exhaust with the flip of a switch. Run it closed, run it all the way open or any position in between. Adjust your back pressure to save gas. Fits any car or truck - from old school muscle car to modern American muscle to high tech imports and even sport compacts. Are you QTEC Equipped?
Also, consider picking up one of our wireless controllers for maximum control, ease of installation, reliability, and flexibility.
Features
  • Available in single or dual kits from 2 1/4 inch size all the way up to 4 inch and everything in between
  • CNC 6061 Aircraft Aluminum Body
  • Stainless Steel Butterfly Plate
  • Stainless Steel Shaft
  • 6061 Aircraft Aluminum Motor Plate
  • High Torque DC Gear Driven Motor
  • Gears Made from High Temp Steel for Long Life
  • Custom Illuminated Toggle Switch
  • Mini Weather tight Connectors for Superior Sealing
  • Socket Head Cap Screws for Proper Fastening
  • No Heat Issues!
  • Used at the GM Power Train Division
Click below to shop and don't forget the promo code above.
Quick Time Performance Products at PFYC - PartsForYourCar
Is this mostly for sound?
Is this made for stock exhausts?
Sorry if they are dumb questions, just have never heard of these before.
Sound and some power depending on where you locate it. Not much but some.
It's made for ANY exhaust - will fit stock or aftermarket. You cut out a small section of the exhaust, weld this in place, and then you're done.
1 - 4 of 4 Posts
