What's up Cruzen. I have a 2015 Cruze lt and I'm trying to buy some new tires. I'm thinking on grabbing 235/45r18 . Just wondering if they will fit with no problem/ no rubbing. Thanks
Check into getting the eibach lowering pro kitI'm running 18s with 225/40r18 on my LT
I'm trying to find a way to decrease the gap on my wheel wells.
OP has not been online since Jan 2017If you go to a 235 you should go to 40 series or the larger diameter will have adverse effects on mpg and acceleration. Probably should look into 245/40-18, wider and not taller. Tire Rack has charts to compare dimensions of the tires they sell. Might possibly need spacers so you don't create rubbing on the inside.
