1 - 4 of 4 Posts
To those who have done spring/shock work on first generation, what did you use to release the top nut/bolt at the top of the strut tower? I see that the repair manual calls for a special tool, a type of socket. If this is necessary, where did you purchase it? Thank you.
And while using the 24mm wrench, did you have to use any type of socket wrench to hold the center from spinning? If so, what did you use?
1 - 4 of 4 Posts
