What? Why?Thanks Shawn. I'm just gonna go sit at an intersection and put the car in neutral. lol
Obviously you didn't read my whole post, I said I assumed it was a chain in because thats what GM used on the 1.4T & ALL other older ecotecs. I can't see them changing things for one motor.He's asking about the 1.8, not the 1.4t
edit:according to this post, its a belt
Timing belt or chain ? - Chevrolet Cruze Forum
*in my best sarcastic voice*1.4L has a chain. 1.6L, 1.8L 2.0L (diesel) have belts.
So I will ask again, why did GM go with the 1.8? Why not the 1.4 and a 2.0 diesel or something? I'm glad I have the 1.4. I would have a hard time buying a 2011 model that still has a belt.
Yes, chains can be better, but they are very expensive to replace. Belts are designed to be changed, and on my 2003 Saturn L300, every 100,000 miles. Chains are usually not designed to be replaced, so there is much more labor involved. On my Altima, the engine had to come out of the car to get the lower timing cover off. My mechanic said there was going to be about 10-12 hours of labor to change the timing chain and guides. And actually my chain was fine, it was the adjusters guide that broke, causing the chain to flap around and break. Nissan uses a double row chain that resists stretching and should last a long time.I understand that timing chains break too, but I'd rather have metal than rubber in my engine. I guess I just remember my first cars with timing belts were junk. You had to replace them at 50-60K almost to the mile or they would break and cause havoc. Maybe the modern versions are better, maybe not. You said your Altima's chain broke at 176K. If I can get that kind of durability out of my Cruze, I'll be more than happy.
On my previous 2000 Saturn LS1, the timing chain was stretched and the adjuster was all the way out at 135,000 miles. Luckily the aluminum Ecotecs are easier to take the front covers off, but still it was $1600 to change the timing chains and all related equipment (chains, guides, water pump, etc).
Most of the vehicles I have had that had timing belts were usually between $300 and $500 depending on what is being changed out. The only exception to that was my GM 3400 TDC engine, which was expensive due to the amount of crap you have to remove to get to the belt and to pull the cam covers.
So either way can cost money, but chains will generally last longer and should be less maintenance intensive. But if you lease, neither option will be a concern.
