I have a 2011 cruze eco lowered about 3 inches and I need new tires. I was thinking about goin a little shorter and more low-profile. And suggestions on brand style and size would be appreciated.
One thing to keep in mind is that going to a tire that has a different outside diameter than the stock tires will cause your odometer and speedometer to be off depending on how big the difference is.
It is also better to state whether you need a set of all-season or summer tires so that others can give better recommendations.
Ha, in regards to brands, whatever I said I had good luck with will be bad luck for you. And in regards to vehicle height, would like to raise mine, already having problems with public entries with scrapping the bottom, and dead meat with over five inches of snow.
And officer, not drunk, just trying to miss potholes in all the roads. With low ground clearance, could really damage the bottom of these things.
