21 - 23 of 23 Posts
Discussion Starter · #21 ·
****.. That I did not. I did shift through the gears but did not check with it running. Could it have been THAT off without running it? Or will it still be pretty close?
that's why you had so much fluid come out. The correct procedure is to get the fluid up to temp, leave the engine running and trans in P and remove the fluid level check bolt.
Okay, I will check that again tomorrow. Will it be about a quart off then now?
Thanks again
21 - 23 of 23 Posts
