So I figured I would bring the diesel pids to the mobile world, and I need testers!
As a requirement you will need the torque pro app and a scanner, which can run between 5 and 50 dollars.
After you have that you will need to shoot me a PM with your Google Play email address. I will then send you a link and you can install the app. Then open up the torque app, open up the app, press the big button, go back, go to settings, add the custom PID group, and then go add your choice of pids to your dashboard.
What sort of custom PIDs?
All the sae pids you get with torque plus
DPF Regen Status
Soot Mass
Dpf Pressure
VGT position
Desired Boost
Balance Rates
A real fuel rate
Engine Torque
ALL 5 EGT sensors
And some other things... But those are the big ones. You will be testing them to make sure they aren't off, and in exchange you will get the app for free (which is going to be spendy so it's a pretty good deal).
DPF Regen Status
Soot Mass
Dpf Pressure
VGT position
Desired Boost
Balance Rates
A real fuel rate
Engine Torque
ALL 5 EGT sensors
