Has anyone had the take out air proceedure work to reset TPMS on a 2016 GEN2 LT RS?
That capability was removed after 2011.Has anyone had the take out air proceedure work to reset TPMS on a 2016 GEN2 LT RS?
I would be concerned the TPMS on one of the stems is bad. Do you know which one is causing the issue, or all of them being "relearned" again? After resetting a second time, may have to contact the tire place and see what is going on and what they can do for you.Second question, we recently bought snows for our Cruze, new steel rims and sensors. A day after install error message and no tire pressure. Go back to tire place and they don't have a relearn tool?? Go to my nearby mechanic and he resets. A day later error message and no tire pressure again. Any ideas? or just reset them again.
I don't think you can clone sensors. The Cruze will only remember 4 sensors, so you'd have to reprogram every time you changed the rims. (Such as mounting winter tires.)Actually they have a ITM Sensor Aid tool but I don't think they know how to use it except to clone an existing TPMS and dada it will not read the original sensors on our cruze.
