1 - 3 of 3 Posts
So, I’ve been having issues with the above sensor indicator lights. I’ve changed the battery cables, no change. I’ve changed the battery sensor, nothing. I’ve changed the the coil block and spark plugs...nope. The engine runs really rough when it drives and the dash blinks like a Christmas tree.
Today, I jump started the engine since I’d given up for a couple of months. The radio would flash periodically and die. The battery won’t keep charge either. The battery is only a year old. Just before it loses all power and won’t start, nearly every indicator lights up on the dash and the wind shield wipers kick on. This is getting ridiculous. I’ve changed all the oxygen sensors and turbo sensor, PCV and the vacuum solenoid(I think that’s what it’s called). What else is left that I haven’t found? I need help!
2013 Cruze 1LT
1 - 3 of 3 Posts
