Service tec notified me I had a transmission leak. Car just hit the 105k mark and has had water pump replaced at 70k with no other costly problems. Wondering if it could be coolant or trans as I has fluid on top of motor. Anyone else experienced this??
290015
290016
290017
That's alot of oil/grim all over the transmission. Separate from the orange stuff. These engines can leak alot if you have a prior problem your unaware of. I would decrease everything. Do a cooling system pressure test to locate a coolant leak. Put oil dye in the transmission to find a transmission leak. Put oil dye in the engine oil to see if there is an engine oil leak.
Or you can pay someone to do all that for you.
2013 Cruze LT
I think that is coolant not tranny...
That's a coolant leak. Always remember that dexos1 used in these cars have a distinct orange/peach color to them.
Considering where the leak is at, the plastic cooling hose "hub" on that side of the engine probably needs to be replaced.
A common source of trans leaks are the hoses to/from the radiator...
2013 Cruze LT
water outlet. 😉
290056
It's probably this. As mentioned, coolant is orange in cruzes unless someone replaced it with the green stuff. Automatic transmission fluid is a light red color. The coolant line that I circled is a two-piece design that's pretty notorious for leaking . I'll warn ya, if it isn't leaking, it probably will when you pull that retainer clip and remove it. They make a new hose that eliminates that stupid two-piece design that you can find on Amazon
Did you degrease everything? Use a can of brake cleaner. I would have thought the turbo coolant line just based on the leak location. I would monitor it for awhile.
