Has anyone changed these out themselves? What special tools are needed? I know the lines connect to the radiator with some type of special connection, can a fuel line removal tool be used for these? How much fluid should I expect to lose during this process?
are your lines leaking at the fittings themselves?
im guessing yes.
i would just buy new trans lines from parts store and use barbed fittings and proper hose clamps like those used for fuel lines
thats how ive replaced several vehicles trans lines, including class 8 dump trucks with allison transmissions
avoids the weak point- the fittings
Thanks for the tip boraz!
I assume the wetness on the bottom of my trans is the cooler lines. I am still under warranty but I think I am going to be looking for an alternate fix, as I want it fixed once for all.
So I'm assuming they will manage to get out of replacing these under warranty?
Changed the trans fluid today, had the car up on a lift and it's dead clear the lines are leaking.
I have a pair of OEM replacement lines I haven't got to replacing yet. I may pop the level plug and see where I'm at and add some as necessary until my work slows down this summer and I can take my time replacing the lines.
