Well I am not sure if this is paranoia or I simply don't trust the car anymore, but whatever the reason is. I am just wanting to get some better thoughts of others & if this is simply normal for the Cruze. Well the other day I notice my Cruze when it came out of 2nd into 3rd it was more jerky then it normally had been. Its more of a hesitating pull into 3rd you can feel it, not hard shift just more of a pulsing type shift. Then the rest of the gears shifts smooth & normal only way to tell it shifts is by watching RPMs, doesn't run bucked up or anything. Sometimes it will downshift like a "drop" into gear - not bucking or anything just like drop & there ya go, very few & between does it do that.
Now I am also noticing a slight metal I want to say from around 30mph like a rattle/mesh type sound doesn't do it at idle, doesn't do it at a stop light, it sounds overall good, just want to clear my thoughts & get some insight on this, I also contacted OnStar & done a diagnostic on the transmission health to make sure no stored codes that the system didn't turn the CEL on for.
So anything thoughts on this & am I simply being just paranoid on the situation?
