Vendor
Meet the GM LFV engine. It's the big brother to the LE2 (the LE2 is due to be released in the upcoming 2016 Chevrolet Cruze). The TRIFECTA calibration for the LFV engine offers substantial power gains and drivability improvements.
https://www.facebook.com/5709299962...929996259628/1152624774756811/?type=3&theater
In fact, as far as we're concerned, 2016 is going to be one of the most interesting years ever. GM is rolling out their "small gasoline engine (SGE)" line to several vehicles in the US (though SGE has existed in other regions for several years now). The soon-to-be-released 2016 Chevrolet Cruze receives the LE2 engine, which is a 1.4L SIDI (spark ignited direct injection) turbocharged 4 cylinder engine. However, aside from sharing similar displacement with the current 1.4L turbocharged engine in the Cruze, Sonic, and other vehicles, there is very little that is similar between the two engines (even the bore and stroke differs between the LUJ/LUV and the LE2).
Its "big brother" is the LFV engine, which is a 1.5L SIDI turbocharged 4 cylinder engine, which is installed in the new 2016 Chevrolet Malibu. Compared to the LE2, the engines share the same bore, but the LFV has a longer stroke (86.6mm vs 81.3mm). Out of the box, the LFV is rated at 163HP / 184TQ vs the LE2's rating of 153HP / 177TQ.
The tuning calibration constructs are also completely new. These engines run at much higher boost pressure (versus the LUJ/LUV) on factory programming and now employ new airflow control constructs not ever seen previously.
SGE is the future of the small displacement engines for GM. The LFV and the LE2 are here now. So is TRIFECTA. Stay tuned for more details as our products become available for the SGE vehicles!
Wow, it looks great! It's about time GM started taking tiny turbo engines seriously. They did a great job with the LUJ/LUV but this is more like it.
Reactions: obermd
Whether we buy or lease our next vehicle will be the 2016 Malibu. If we decide to buy, hopefully you'll have a tune ready to go. Currently our 2014 Malibu has the 2.5L engine and it rated at 197hp and 192ft-lbs of torque, it would be nice to surpass those numbers with 1.5T. Especially considering that the 2016 Malibu will be 300lbs lighter.
Vendor
Our results so far are promising! We were actually surprised at the amount of peppiness this little engine has down low on the stock calibration. Even when passing on the highway! The new 2016 2,0T Malibu with the A8 is also quite surprising.We weren't expecting the results we are seeing on the A8 compared to the outgoing A6 :)
COTM Winner
Due to the lower power rating of the 2.0T? Or due to extra gears? 8-speed seems to be the optimal amount for an auto - and sometimes they can do some real fun things...the ZF 8-speed that FCA uses will do a WOT, non-sequential 8-2 downshift, which is always a blast. I'm guessing this might have a similar function?
Vendor
Yeah, due to the A8 and some specific changes to the 2016 ECM code GM has made. Of course, the small drop of 300lbs from the outgoing model helps as well. The A8 allows for these short, snappy shifts that keep you in the meat of the power band. It's quite fun!
