what psi do you get when its back to stock? If its around 14 psi then we will know that the elevation has nothing to do with it.
I am at basically zero feet but mine never strays above 14psi with the cruise control on.This is my last attempt to be nice with trifecta. I installed a boost gauge. In both eco mode and perf mode i see 22psi. I purchased a select a tune. Correct me if im wrong but should i not see 12-14 psi in eco mode (with cruise control enabled)?
Vinces response was "its your elevation".
Omfg so you are telling me that because i live at 4000ft ill get 22 psi even though you told the pcm to only boost 14?!
Please tell me if im wrong because im about to cause problems for vince. Im so sick of this!
Sent from my Galaxy S3
Here is a question for him. If its all about elevation, then why isn't you 22psi tune boosting higher than it should as well?This is my last attempt to be nice with trifecta. I installed a boost gauge. In both eco mode and perf mode i see 22psi. I purchased a select a tune. Correct me if im wrong but should i not see 12-14 psi in eco mode (with cruise control enabled)?
It does have to do with your elevation levels. Mine will go up to about 19psi in eco mode. Where i live is about 400ft above elevation.
I've seen the same thing in mine in the "eco" mode on occasion. It happens more on hot/humid days than on colder, drier days.It does have to do with your elevation levels. Mine will go up to about 19psi in eco mode. Where i live is about 400ft above elevation.
I am definitely seeing the same as Sciphi, with ECO mode. Hot 90+ temps seeing 21-22 psi peak boost. Since it has been cooler more like 18 psi peak in ECO mode.elevation.I've seen the same thing in mine in the "eco" mode on occasion. It happens more on hot/humid days than on colder, drier days.
I really wouldn't expect elevations below 4,000 feet to have much difference given that my stock tune ECO MT doesn't start showing signs of shortness of breath until it's over 10,000 feet. There is a lot of head room in that turbo for compressing lower density air.Thanks. Ill check the stock tune.
I dont want to hear anything about elevation 1) it isnt relevant here 2) ive already proven to vince that there is little difference between my car at 0ft, 2000ft and 4000ft. Have logs to prove it.
I will retune stock and report back.
Well, 1) I already paid for a tune that I can't return for a refund 2) The wife says no.titan2782- if I were you, I would re- flash to stock & just drive the SRT-4 when I get the urge for some fun. Am sure the wife won't mind![]()
Feels exactly the same in both modes. After I switched back to stock tune, I noticed a huge difference in drivability. I tried to pull out into traffic and almost died. Ok, maybe not almost died, but I certainly didn't get the response from the car that I have come to expect.Hmmm, that is odd. Sorry buddy I don't know what is wrong! I guess the question is.. does it FEEL like it is pushing 22 psi in eco mode?!
Well, that just seems like a problem with getting "eco" mode to work. Eco should be 14 psi and be slightly weaker than stock.Feels exactly the same in both modes. After I switched back to stock tune, I noticed a huge difference in drivability. I tried to pull out into traffic and almost died. Ok, maybe not almost died, but I certainly didn't get the response from the car that I have come to expect.
So having said that, I would expect eco mode to be similar to stock tune as far as feel.
Either way, the gauge reads 22psi in both modes with tune and 14psi with stock tune.
