Hello, I just got done installing my two 12 inch kickers with a 1200 watt amp to my 2014 cruze. I used a line out converter and tapped into to stock radio. I ran the power to the post on the battery side of the built in fuse then hooked my remote wire to an add-a-circut and plugged it into one of the 20 amp power outlets on my Fuze box. After everything is hooked up I'm not getting any power to my amp. Wondering what I did wrong. I used a 40 amp inline fuse to my sub power wire when I accidentally broke my 80 so idk if this is contributing to the issue. Also I grounded it to the body right behind the back seat with a self tapping screw after sanding the paint off. Any advice would be very much appreciated!
