Trunk Latch will not open WITH FOB OR BUTTON.
Today I disconnected my battery. It was off for at least an hour while i ran wires to my new amp and sub woofer. after it was all wired I had to reconnect the battery to open the trunk to test the system and it opened like normal. After 30 minutes of the trunk being open and disconnecting the battery to put everything back together I reconnected the battery, closed all of my doors and now the trunk will not open. Neither the FOB or the button releases the trunk, only the interior trunk release opens it. I used WD-40 on the latch as it was a little dirty but no rust or anything; I disconnected the battery again to see if it did anything which it did not. I disconnected the power from the amp(and sub) at the battery terminal to see if there was interference, No change. I grounded the amp to a bolt inside the trunk; it was on the left in the center and it had 2 things already being grounded to it. I grabbed my second key fob from in the house, and the same thing happens, no release. The car will flash the lights twice if i hold the trunk release button. All other features work like normal. Do i need a FOB reprogrammed? but why doesn't the button work? When i have the trunk open, if i close the latch neither the key or button release it. I can hear an audible noise coming from the dash when i push the trunk release.
